need help to compile my C program. It keeps telling me i have errors!** new Problem**
Mucman
7,246
Umm, the error messages seem pretty self explanatory...
your main function should be declared
int main()
// code here
return 0;
<edit>I guess you figured it out :)</edit>
imported_vr6
2,740
ok i got it, thanks.
Ok one more thing, how do i get the program to display the comments in the beginning?
RSMemphis
1,521
<< Take "\n" out of all of your scanf calls. >>
Edit: if necessary (it is not), you can put a \n at the beginning of your printf strings.
But the \n at the end of the scanf input string messes you up. Scanf is picky.
Adrian Tung
1,370
<< Ok one more thing, how do i get the program to display the comments in the beginning? >>
You can't, unless you printf them out. Comments are only meant for internal use, they don't get into the binary after you compile the code.
:)atwl
