Need Help To Clone Entire OS !
Apr 2, 2008
28
I want to make an image(clone) of my C:drive(Windows XP Installed) so that I can restore my entire OS later or copy to other PC easily.
I need a nice and easy to use software.
Which one is better Partimage or Clonezilla or Norton Ghost or Acronis True Image ?
Or any other you want to recommend.
Please guide me!
I have no idea how to use these programs.....
Thank you !
BlueWeasel
15,944
475
Acronis TI is the best, IMHO, but it's not free. I think that Driveimage XML and Clonezilla are both free but have no experience with either.
Ken g6
Moderator
Dec 11, 1999
16,621
4,539
75
Also be aware that if you have a copy of XP without a site license, and you install an image of it to a computer with different hardware, you will probably have to re-register it with Microsoft.
Ayah
2,512
Occasionally there are giveaways of "old" versions of Acronis TI. If you look hard enough they turn up left and right.
I don't imagine they're going to stop anytime in the future so might as well keep updating every year or so. ;)
corkyg
Elite Member | Peripherals
27,370
239
Acronis TI is the best cloner I have found - when used with its bootable CDR. Clonezilla works, but is not what I consider "user friendly." You get what you pay for.
Be aware that if you install a drive cloned from computer A in computer B, chances are you will get a BSOD quickly unless they have identical chipsets/mobos.
bruceb
8,874
111
I also registered for that, got my acronis password, but never got the install code or the download link. And I did check the spam folder. This now since yesterday 2/4 ... who knows, it may still show up.
theAnimal
3,828
23
Originally posted by: Revolution
Originally posted by: theAnimal
Clonezilla worked well for me.
Can you give me a good tutorial link ?
I'm totally noob in linux
Didn't need a tutorial, it's pretty straightforward. I don't use Linux.
Chadder007
7,560
I like Clonezilla more than Acronis so far.
