Need help to clone a dynamic disk
mooncancook
I want to replace my 2TB disk drive with a 2TB SSD directly. Problem is that the hard disk is a dynamic disk with 3 partitions which contain apps and games. I've tried EaseUS and AOMEI, both can only clone one partition of a dynamic disk at a time, which I am concerned that will cause problem for the installed programs and games. Any program or method out there that can clone a dynamic disc with multiple partitions, free or paid? Thanks.
Have you actually tried it? If it doesn't work then you can always go back to your other disk, but using EaseUs, moving the partitions over, and resizing accordingly should not cause any issues. You may need to re-assign or correct drive letters at the most.
I haven't actually tried it. I'll have to try it if there is no other solution. I prefer not have to do a lot of trouble shoot, and cloning large amount of data takes a lot of time. Another concern is that if I remove the old drive and put in the new drive and if it doesn't work, I don't know if it will create problem when I put the original drive back.
