need help techies, possible audigy platinum problem
Chapter11
Ok, here's the deal. I'm getting a blue screen of death whenever I run any of my games. The error is like this.
"IRQL_NOT_LESS_OR_EQUAL
(then below it it says check your drivers and what not to make sure everythings installed right, yada, yada.)
STOP:0x0000000A
begging dump of physical memory."
A few things you should know.
Now I didn't start having these problems until after I installed my SB Audigy Sound Card. So of course I think it's a confict between the sound card and something. Whats wierd though is that I can run any program on my computer and listen to mp3s, etc. I only get this problem when I play games, any game. Then the BSOD will pop up randomly in the game with that same error.
I have got all the updated drivers for my sound card as well, but it still does the same thing. Here's a little bit of my system specs if this helps.
Windows XP Proffesional
Athlon XP +1700
Iwill XP333-R mobo
Crucial PC2100 DDR
Visiontek Xtasy GF3 ti200
Thanks,
disabling the com2 port didn't work, but there was a conflict.
Windows didn't detect it, but either my modem or my nic card were grabbing at the same system resources that my sound card was. So thats where the conflict came from. I took both of them out and am still trying to figure out which one caused it.
