Hey everyone, ever since my computer troubles about a year ago i havent even thought of overclocking anything... (My mobo died, then CPU died, etc).
About a year ago i bought a Athlon XP 2500+.
Here is what CPU-Z said
CPU-Z version 1.21.
CPU(s)
Number of CPUs 1
Code Name Barton
Specification AMD Athlon(TM) XP 2500+
Family / Model / Stepping 6 A 0
Extended Family / Model 7 A
Package Socket A
Technology 0.13 µ
Supported Instructions Sets MMX, Extended MMX, 3DNow!, Extended 3DNow!, SSE
CPU Clock Speed 1833.1 MHz
Clock multiplier x 11.0
Front Side Bus Frequency 166.7 MHz
Bus Speed 333.3 MHz
L1 Data Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L1 Instruction Cache 64 KBytes, 2-way set associative, 64 Bytes line size
L2 Cache 512 KBytes, 16-way set associative, 64 Bytes line size
L2 Speed 1833.1 MHz (Full)
L2 Location On Chip
L2 Data Prefetch Logic yes
L2 Bus Width 64 bits
Mainboard and chipset
Motherboard manufacturer ASUSTeK Computer INC.
Motherboard model A7V333, REV 1.xx
BIOS vendor Award Software, Inc.
BIOS revision ASUS A7V333 ACPI BIOS Revision 1017
BIOS release date 03/25/2003
Chipset VIA KT266/333 rev. 0
Southbridge VIA VT8233A rev. 0
Sensor chip Asus ASB100
AGP Status enabled, rev. 2.0
AGP Data Transfert Rate 4x
AGP Side Band Addressing supported, enabled
AGP Aperture Size 64 MBytes
Memory
DRAM Type DDR-SDRAM
DRAM Size 512 MBytes
DRAM Frequency 166.7 MHz
FSB
RAM 1:1
DRAM Interleave 4-way
CAS# Latency 2.5 clocks
RAS# to CAS# 3 clocks
RAS# Precharge 3 clocks
Cycle Time (TRAS) 6 clocks
# of memory modules 1
Module 0 Micron Technology DDR-SDRAM PC2700 - 512 MBytes
Software
Windows version Microsoft Windows XP Workstation Service Pack 1 (Build 2600)
Thanks,
Richard
CPU-Z version 1.21.
CPU(s)
Number of CPUs 1
Code Name Barton
Package Socket A
Technology 0.13 µ
Bus Speed 333.3 MHz
L2 Location On Chip
Memory
DRAM Type DDR-SDRAM
FSB
Software
Thanks,
Richard
