Trying to setup linksys wireless 801.11b router to work with the laptop. I want to enable security and router gives me 4 choices:
WPA PreShared
WPA Radius
Radius
WEP
Now switch to the laptop part: it does see the wireless network, but when I try to connect to it, I'm being asked for the network key. It would only accept 5 or 10 character keys. I tried every possible combination between the router and the laptop - no dice.
The laptop is IBM ThinkPad w/ Centrino if that makes any difference. If it would make life easier you can IM me at argo516.
Thanks in advance.
P.S. One more question. I'm going to hook up my TiVo through wireless as well. I bought LinkSys USB wireless adapter. Will I still be able to use security, or is MAC filtering my only alternative?
WPA PreShared
WPA Radius
Radius
WEP
Thanks in advance.
