Does anyone here have a GA-8INXP setup with MBM? I'm trying to get my setup properly as far as the voltage section goes. The default setup of voltage in MBM on the 8INXP is wrong. The reading on the +5, +12, -5, and-12 are incorrect at the default. There is a selection box in the voltage section of MBM ( called Voltage Configuration) that you can assign any of 4 sensors to the other box that has the selections you can set for Voltage 8-16. Has anyone got this setup correctly, and if so, how??
Thanks
Thanks
