Need help setting up NAT32
goog40
4,198
Ok, now I need some help setting it up so I can play CS through NAT32 from another computer on the network. As far as I know, the ports I need to set up for CS are 6003, 27005, 27011, 27010, 7002, and 27015. Now how exactly do I get that set up? I tried the ppmap command shown on their help page, but I'm either not doing it right or its the wrong thing. Their help page:
http://www.nat32.com/htm/index.htm
Thanks
I have my two computers networked together, and one computer is hooked up to the cable modem and it runs the proxy software from AnalogX. I was wondering if there is any proxy or similar software that allows you to specify which ports to allow(so I can play CS on the other computer too). Thanks
goog40
4,198
Alright, thanks guys. I thought I might be looking for the wrong type of software. I'm using Win98 SE so I'll go with NAT32. Thanks again:)
