- Sep 13, 2007
- 7,228
- 19
- 81
This just isn't making sense to me, I must be dense on the subject. Here is the system I have. What is going to be the best combo of quality compared to what he connections are capable of. I'm certainly willing to not use all 8 cameras if it means a better picture on the rest. I want the front door to be as high a quality setting as possible. On the same hand don't want to put it on setting the camera isn't capable of. It has a 1TB HD and would like to be able to record a week if possible. Here is the text from the manual:
Under RESOLUTION, select CIF, HD1, or D1 or QCIF. NOTE:
Channels 1 & 2 allows options D1, HD1, CIF and QCIF.;
Channels 3-8: allow settings of CIF and QCIF.
2. FRAMERATE: Choose the recording frame rate 1-30, (fps frames per
second). The lower the value, the less life-like and more jerky the recorded movements will be. However, a lower frame rate uses less HDD space. Make your choice depending on the precision with which you want to follow the events being recorded. Frame-rate of each channel can be adjusted
but is limited by the total resources available. The total frame rate for all channels combined cannot exceed 420 (NTSC) fps. The ratios of D1, HD1 and CIF are as follows: 1 D1= 4 x CIF, 1 HD1 = 2 x CIF.QCIF=1/4 CIF.
3. QUALITY, The quality rating is on a 6 point scale. The selections are 6-High, 5,4,3,2,1-Low.
