I have the following components:
Duron 650@800
Abit KT7 (Latest bios WZ bios, not RAID)
20 Gig WD hard drive
Hercules GeForce 2 MX (32 Meg AGP).
Soundblaster SCSI-2 ASP sounds card on ISA bus (SCSI doesn't work, wants IRQ 9 because it's not available).
HSF (I/O Magic) Winmodem on PCI slot 4.
I've attempted to install a Linksys 10/100 network card but keep getting system lockups. I have tried to install this card on each and every slot. I've also obtained the latest drivers from Linksys. I can take the modem out and install the Linksys sucessfully, but can't have both in at the same time.
The problem seems to stem from IRQ conflicts. I have attempted to manually set the IRQ's in the PCI/PNP configuration menu. As I boot, the ACPI function reassigns the IRQs.
I've looked all over the internet and the newsgroups but have not found a clean way to fix this problem (I do not want to use a hacked bios as some have proposed.).
How can I disable this ACPI function or how can I install this card into my system without lockups? By the way, I've tried to install at stock clock and this doesn't work either.
Appreciate any help!
Duron 650@800
