Need help setting up Java on my machine...NEED HELP ASAP!
I am supposed to be using this -
Java Image I/O
and have d/l java files from here
Text
i d/l both Windows (all languages, including English) for JRE and SDK
am I missing something to d/l to get the Image I/O working?
i could not find javax anywhere on my computer
but i cant seem to be able to write a simple program like this
File f = new File("c:\images\myimage.gif");
BufferedImage bi = ImageIO.read(f);
because it doesnt recognize File or BufferedImage...
did you load the appropriate classes?
obviously if you do not have those classes available to the compiler, the compiler is not going to know what they are.
Refer to your favorite Java tutorial or introductory textbook (or Google) and lookup the import statement.
Not just that also the entire packages system.
(Here's a helper: import java.io.*; )
