I have aquired two older RS/6000's (PPC 333MHz) with 256MB RAM each and each have 2 2.1GB SCSI drives each, and a cdrom. They also have IBM SSA cards and I have an external storage array box with 5 9.1GB drives in it that plugs into both for shared storage. Each machine has two NIC's, however neither has a video board (both ran only from the console).
I would like to set the two up in a cluster (for the hell of it) and I would like to run linux. According to IBM's site, AIX is the only certified OS, but I bet with some work linux will work.
I'm guessing my first try will be to use linuxppc(downloaded from here )
I have no idea how to setup a cluster at all nor how to do so only using the console port, so any help and/or links would be appreciated.
I figured I could run a crossover between two of the NIC's for communications between the boxes, and the other NICs to my switch.
Also, does anyone have any idea if I went ahead and installed X if it would run remotely through my windows box (maybe using xwin32 or hummingbird), or maybe through my laptop running RH71?
Thanx for any info
Thanx for any info
