Hello- I recently came across a HP Deskjet IIIsi with a network card as the only interface. I figured a NIC and a crossover cable was all I needed to run this beast from my box... well it's not working. I installed the NIC and drivers properly, the printer drivers as well, but it doesn't seem like the printer is getting any information from the computer. I can see myself and the printer in the network neighborhood fine. I seem to think I need to do some TCP/IP configuring somewhere, but I don't know where to begin. Also, I noticed that in my network config screen, I can add something called HP JetAdmin--Do I need this installed? It would seem like I do, but for some reason the file can't be found on my windows cd. Is this what my problem is, or is there any workaround? I guess I'm just not as smart as I thought, so if someone could break it down to me, I'd appreciate it. Thanks.
