Need Help setting up a new Motherboard
Rsnider1961
18
I have just purchased the components for my first home assembled system as follows:
Gigabyte 8PE667 Ultra2 Motherboard
Corsair XMS TwinX512-3200LLPT memory
Asus V9280S Ti4200 Video Card
Intel P4 2.66Ghz Processor
Antec 1080AMG Case with 430w PSU
Lite-On 16x DVD
Memorex 48x24x48 CDRW
Logitech Z-640 speakers
Dell 18.1" 1800 FP LCD
Anyway - I am having problems deciding where and how to hook everything up. For example - on the sound, is the black wire negative or is the orange wire negative.
On the Power - is the white wire negative or is the green negative - and on the reset, is the white negative or the blue negative.
I would appreciate it if someone would PM me with some help.
THUGSROOK
11,847
the sound can go either way ~ if its wrong the speakers will be reversed.
ide and power light work the same ~ if it dont work reverse it
the power and reset dont matter
speaker dont matter
HTH :)
Mucker
2,833
This works for me:
Do you have a mainboard diagram? If so,
Reset SW: Pin1 = blue wire
Power LED: Pin1 = green wire
Power SW: Pin1 = green wire
Speaker: Pin1 = Orange wire
HDD LED: + = Red
Antec's directions are wrong for the 1080AMG, at least for my mainboard Epox4pea+. Antec says to have all of the labels facing the front of the case but this is incorrect. Eveything works fine as stated above for me anyway....
Rsnider1961
18
Thanks guys - will hook up and try my luck. Planning on oc'ing when I get everyting going - will need help in these areas also.
Mucker
2,833
There are a ton of knowledgable people on this forum that help out tremendously everyday. I have learned a ton of information from forums such as this one. There are other forums that are very good also at sites such as overclockers.com, amdmb.com, and asusboards.com (just to name a few) :)
GPJ
Rsnider1961
18
How does this setup of parts sound - anyone have any suggestions on what I need to do help it rund better and faster?
Johneverd
483
HERE is a book called "Upgrading and Repairing PCs". It's an older version, but still has A LOT of great information. This is the complete on-line version, not a book for sale. Read it on-line for free.
