Need help setting up a FTP server!
codyray10
854
4
I've taken an interest in trying to set up a little FTP server. I came across a program called FileZilla that seemed pretty popular for doing so, but I dont fully understand it or have the general 'know-how'. I've gotten to the point where I can get into it from my computer that I set it up on, but not from the other computer on my home network, or any other external computers.
Does anyone have any experience with this program? Or setting up an ftp in general, and could possibly give me some help. Anything would be greatly appreciated.
dbarton
767
Filezilla just connects to an existing server on a machine elsewhere.
Unless I'm confused it won't set up an ftp server at all.
Ken g6
Moderator
Dec 11, 1999
16,836
4,816
75
Seems like it used to be that way, but now FileZilla has a Windows-only server.
codyray10
854
4
Yeah I believe you're thinking of FileZilla Client. They have a server app now, thats what im using.
ChunkiMunki
449
I would create an anonymous acccount folder/login and try to connect with a client from other computers on your network. Then when you get more confident, add a password folder/login with different permissions. To connect from the internet you need to open up the ftp hole in your firewall or router. It takes some practice and trial/error, but you'll eventually get there.
Ika
14,264
For my FTP server, I use FileZilla server interface and a DynDNS IP router (basically, it connects my dynamic IP to a static DNS, so I don't have to look up my IP every time someone wants to connect to me).
codyray10
854
4
When I would try to connect to it from the other computer just using IE, it would give me the ftp login prompt. Once I provided my login it would load for a few and then go to 'page cannot be displayed.' So I completely turned off my firewall on the machine hosting the ftp just to see what would happen then, and it worked! So Firewall is obviously the problem. However, I've made all the exceptions I am supposed to! I think anyway. I've added FileZilla.exe to the exceptions and also added port 21 as an exception. I've logged in to my router and forwarded ports 21-22. Still nothing though if I keep Windows Firewall on. Hmmm.
codyray10
854
4
After turning firewall off and then turning it back on it works fine. I still cant get any external machines connected (computers outside of my network) Any suggestions?
mc866
1,410
If you are behind a router be sure to forward port 21 to allow incoming connections. Next be sure to go into the windows firewall and allow an exception for Filezilla server.exe, make sure you don't use Filezilla server interface.exe. Lastly under the Filezilla server options make sure to go to the passive mode options and select use the following IP, and enter your external IP address. These are the steps I took to be able to access my FTP server from outside my network.
codyray10
854
4
I've already done all of the above. When you say "enter your external IP" could you explain which IP that is exactly. I currently have 'use the following ip' as 192.168.1.100 which is the ip address of the machine I'm hosting the ftp server on. Is that right? With all the exceptions made in windows firewall and ports added/forwarded, I can get in from my local network but not any machines outside of my network.
mc866
1,410
So 192.168.1.100 is your local ip, you'll need a static ip to use if you want access from outside your lan. I've been using the NoIP free service. Set it to run as a service when your computer starts and it will spoof a static external ip. Once this is set you enter this ip into the Filezilla setup. You can also setup RDP with this external ip if you like too.
Hope this makes some sense, let me know if you have questions.
codyray10
854
4
Think you could give me a sort of walkthrough with this NoIP. I checked run as service. Under connection I selected Override auto connection detection and selected my ethernet adapter. Logged into my router and forwarded port 80. In the NoIp it says my current ip address is 98.209.226.81. Where do I go from here?
mc866
1,410
So once it's up and running you should see an icon for it in your system tray. If you mouse over it you should see the ip it's assigned. To double check that it's working go to the web and google what's my ip. The browser results should match the ip listed by Noip. If it does this is considered your "external" ip. Put this ip in the filezilla config and try and connect from an external computer.
mc866
1,410
Appears to work, I see a bunch of files. You should see that I logged in also.
mc866
1,410
Not a problem, happy I could help. I struggled with my first install a bit too.
z0mb13
18,106
Hello all I did all of the above but whenever I try to connect to my server using my external IP i get the following error message: "425 Can't open data connection"
Thanks for any help!
Ken g6
Moderator
Dec 11, 1999
16,836
4,816
75
Can you set your FTP client to use "passive FTP"?
z0mb13
18,106
Yes I did follow mc866's example and use passive FTP, but it still doesnt work
If I connect locally it works, but if I connect from external IP I get the 425 error message..
Some specs if it matters: visa ultimate 32 bit, wireless router, cable tv internet
mc866
1,410
Just to verify you've done the following
Did you forward port 21 on your router?
Did you allow an exception in the windows firewall for filezilla.exe?
You've setup your noIP client,
Have you made sure to set the filezilla settings as passive and use the IP number that noIP has given you?
