Apparently there was a batch of G.Skill RAM that defaults to the wrong timings. I currently have everything set to auto, the way it was out of the box. I need to set my timings to 3-4-4-8 but I have no idea what to do.
Well first I would run memtest, it's quite possible your memory will be stable at those timings. If not stable let me know..I'll reboot my computer so I can look in bios to tell you what to change.
