- May 11, 2002
- 16,019
- 11,139
- 136
1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
mainly photoshop and heavy graphic use in the office
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
$1300 approx, $1500 at the most
3. What country YOU will be buying YOUR parts from.
US
4. IF YOU have a brand preference. That means, are you an Intel-Fanboy, AMD-Fanboy, ATI-Fanboy, nVidia-Fanboy, Seagate-Fanboy, WD-Fanboy, etc, etc, etc, you get the picture.
I'm thinking this for motherboard: http://www.newegg.com/product/...p?item=N82E16813128083
And a intel 45nm quad core.
So Gigabyte and Intel
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
Monitor, Speakers, Keyboard, Mouse, Printer
6. IF YOU have searched and/or read similar threads.
7. IF YOU plan on overclocking or run the system at default speeds.
Stock settings
8. WHEN do you plan to build it?
2 weeks
Additional information:
I need something that has very good cooling (not water, but enough to work in 120-125F degree heat with some humidity without problems).
Another thing I require is lots of USB slots and a case where the front USB actually work (had problems with this in the past) and wireless networking capable.
Decent video card and sound card (or onboard sound)
So what do you guys suggest? ($1500 or so should be reasonable, and please suggest good dvd burners too, I don't want coasters at work)
Can you guys suggest the rest?
Thanks a lot.
US
Stock settings
2 weeks
Thanks a lot.
