Older thread, but I thought I'd post something about iPods. I've had 4 ipods, a 2nd gen, a Ipod Video 30GB, an Ipod Nano, a 2nd gen Ipod nano. Of the 4 2 of them have gone bad after the warranty period expired. Since I am not under warranty and require service apple charges me $129 to fix it plus $7 shipping each way. That's almost the price of a brand new iPod. Who in their right mind would pay that outrageous amount for an old product when for about $50 more you can buy a brand new (newer generation too) iPod or something else?
My advice, don't buy Apple products. They rip you off. Personally my next purchase will be the new Zune 80GB. It's the same price as the 80GB IpoD classic, but has wiFi, an FM Tuner built in, and much much better headphones. The screen is larger as well. I also feel that the scroll wheel on the ipod is not as easy to use as the Zune's.
If you're curious about what happened with my ipods, the center button is broken on one and no longer functions. The other one crashed while trying to transfer songs to it and now it shows an erased HDD and iTunes just freezes when I try to plug it in so I can not reset it per Apple's recommendation. It's a paperweight unless I want to pay nearly $150 to repair it. Which I won't do when I can spend a bit more and have something better IMO.
Just thought I'd share that.
