Want to get a mini system for under $150. Only requirement is that it have a 3 cd changer. The type of music being played will be low volume, relaxing as it will be used by a mesage therapist. Suggestions?
I have this old Aiwa mini-system, but the CD player does not work anymore after a few years. Same with my brothers. If you drive to NJ you can come pick it up for free. 🙂
