I recently started messing around with an older desktop computer that i built about 5 years ago. Right now all i am looking at doing is just adding in a video card to run dual monitors, since the computer is only going to be used for daily use and no games. I still want a video card that runs applications smoothly and wll run everyday applications with no problem. I have been looking at tigerdirect for some video cards, and i found the cheapest 3 after rebates, so i was just wondering which one you guys would recommend and why, also if it is compatible with my computer. I would just build a new computer but am budget contrained at the time. Thanks!
Motherboard
http://www.newegg.com/Product/Prod [...] 6813121049
CPU
http://www.newegg.com/Product/Prod [...] 6819116001
Power Supply is 450 Watts
Possible Graphics Cards
1. http://www.tigerdirect.com/applica [...] CatId=3668
2. http://www.tigerdirect.com/applica [...] CatId=3669
3. http://www.tigerdirect.com/applica [...] CatId=3670
Motherboard
CPU
