- Mar 8, 2001
- 12
- 0
- 0
Thanks guys for helping me decide/select a suitable mother board. I decided to go with ASUS CUSL2-C motherboard, Intel IGHz CPU, 256 K RAM (Kingston), Plextor 16x10x40 CD-RW (IDE, not SCSI as I had earlier considered, thanks to y'all). All for just under $800.
Now, I need to decide between getting a CD-ROM or a CD/DVD ROM. Can you guys please suggest a good brandname/model? I am leaning on getting a CD/DVD because it will be multipurpose. Also, it seems that the prices between just the CD-ROM and DVD-ROM are not too far apart.
What do you say?
I need some sound advice and a response by tomorrow as that is when I will place the order.
Thanks in advance,
What do you say?
Thanks in advance,
