ok, so I lost my starcraft cd case but I need to install it on this PC.. I have it on my other PC so I want to retrieve my cd key somehow. Is there a program to view your cd key?
I'm not sure that there's a program that will retrieve the key for you.
You could just install with some random key (easily googled), and then copy the StarDat.mpq from the old computer into the Starcraft directory on the new one.
