need help removing stripped screws
S Freud
4,755
Bought an xbox and I need to open it up, the only problem is the guy that i bought from stripped the screws and didn't tell me. any good ideas how to remove stripped screws?
thanks
BW86
13,114
30
Did you look on google before posting this?
I just did and found alot of sites that tell you what to do.
slag
10,473
Originally posted by: Heisenberg
Text
Those dont work on stripped screws, just stuck or broken screws
you cant get a "bite" on the screw to remove it if its stripped and freely spinning.
Heisenberg
10,621
Text
Whoops. I thought you meant the head was stripped out.
PlatinumGold
23,168
if i'm reading this thread correctly, the screw isn't stripped the threads the screw goes into on the xbox are stripped.
if so, then you just need to get a thin srew driver under the head of the screw and pry up.
bmacd
10,869
Originally posted by: iamwiz82
Dremel + cut-off wheel = slot in screw + flat head screwdriver = No screw
normally i'd suggest that, but i'm willing to bet all the xbox screws are recessed into the unit.
-=bmacd=-
