I did a clean install of XP Pro SP1 on an old Athlon machine and I can't get IE to work. The old copy of XP installed IE6. Windows itself appears to work fine, but when I start IE it goes to default homepage, blinks a few times, I have no mouse control, and then I get the error screen that says it has a problem and needs to close. So, I can't update XP or drivers or IE. I've done the reinstall twice and got the same behavior both times. The machine is wired to an ATT Uverse Gateway in a network with one other computer but for some reason it doesn't see the other computer...I don't know what this would have to do with IE not working but I thought I'd mention it. Any suggestions appreciated.
