Need help regarding hard disks
- Excruciatingly slow bootup with HD present on secondary IDE channel
This problem is driving me nuts. Any help will be greatly appreciated.
Currently, I have two hard disks and one DVD writer installed on my PC:
Primary Master - Maxtor 2F040L0 (41.2GB @ 7200 RPM)
Primary Slave - WD400 (40GB @ 7200 RPM)
Secondary Master - HP DVD Writer 200j
Secondary Slave - Free
Now my problem is, whenever I install another hard disk on the secondary IDE channel, the system bootup speed slows down to the crawl of a snail. Normally, it takes less than 10 seconds for the BIOS to detect all the IDE devices and begin booting Windows. With another disk installed however, the process takes about a minute to complete. Not only that, what is supposed to be a 20 second load from BIOS to the Windows login screen becomes a four minute wait. Four minutes for Windows to load, just because of another hard disk?! I have made every attempt to cure this problem - to no avail.
I've tried:
- checking the jumpers. Everything was fine.
- assigning the hard disk as master, and the DVD writer as slave. No difference. The BIOS still struggled while detecting the hard disk on the secondary IDE channel.
- using a different hard disk which was fully working. No difference.
- using two hard disks on the secondary IDE channel. The BIOS struggled detecting both hard disks.
- running chkdsk on all my hard disks. Everything was dandy.
- removing the DVD writer. No difference.
From this point, I sort of lost my mind
P) and tried:
- clearing the CMOS. No difference.
- reinstalling Windows. No difference.
- fiddling around with any BIOS settings I could get my hands on. No difference.
- reassembled my computer from scratch, checking for any damages/disconnected cables and components. Still no difference.
And now, I have given up and am asking for help. I find this problem rather strange because previously, my computer was more than happy with hard disks on the secondary IDE channel. It didn't slow down at all like it's doing now. This problem began happening after disconnecting and then reconnecting the hard disk on the secondary IDE channel (for cable rearranging). The only conclusion I can come up with right now, is my computer no longer likes hard disks being on the secondary IDE channel for some odd reason. Only hard disks, because my DVD writer gets detected fine without any slowdowns.
I just hope this isn't some serious hardware problem...
Please help!
Thanks in advance.
I've tried:
Please help!
Thanks in advance.
