Hi Forum,
Well, I didn't think I'd be in this position having spent dozens of hours reading and researching but here I am.
I recently built a system with which has been running fine for the last three months. Feeling confident and having done lots of reading (or so I thought) I thought I'd try an overclock since I this had been in my mind when I picked the parts for the system. The components include:
NeoPower 480W PSU
A8N SLI Deluxe board
AMD 3200+ Winchester 90nm
1gb OCZ EL Platinum Rev2
PNY 6600GT PCI-E video
I spents hours attempting to find the right timings for a stable 1:1 overclock of 240X10 at DDR400 and 1T I resigned myself to having to run at 5:6 or DDR333. The system would run fine and stable at 240X10 with my RAM running at 200 but not with the RAM overclocked at all. Memtest errors galore.
SO last night I worked up to 260X9, 1T, 3X HTT, DDR333, 2225 timings, with voltages at 1.5 and 2.7v. Booted up fine, ran CPU-Z, ran Sandra and benchmarked memory and CPU, hit close on Sandra and crashed. Could not boot up just black a black screen. I thought at worst I will need to reinstall Windows. Overnight I removed CMOS battery, cleared RTC RAM jumper and this morning when I try to power up......nothing.....no fans, no lights, just the green LED inside is on.
Any thoughts? I didn't think I would fry the CPU or MB with the voltages I was using so I'm not sure what's up?
Thanks for any help.
Cheers,
NeoPower 480W PSU
Cheers,
