need help! radeon 8500 le!
loserbutt
Hey, I have a 230/230 radeon le and I've been tryign to overclock it using rage 3d tweak. only problem is that everytime that I try to change it the screen goes to all these colors, like the television color tests of old. any help would be appreciated!!
Not sure specifically what the problem is but I can tell you the LEs are not the best overclockers. They have slower ram, are designed to provide less voltage to the ram, and have bios (on card bios,not system bios) settings that are prohibitive to overclocking. Your not likely to see enough of a performance gain to risk your card.
