- Feb 22, 2003
- 2,461
- 0
- 0
I have my system housed in an Antec Sonata case but as the saying goes..put noisy components in a quiet case and you will still have a noisy pc!
I do not have the probe or the limiter for the SMART Fan II so mine is running >4500RPM and it is quite loud. It keeps my 2.8 @ 3.2 ghz P4C frigid [Thermaltake SLK-947U heatsink] but it is like being next to a jet engine..and as the pc is on the opposite side of my room this is quite aggravating. is there any way i can reduce the speed of this fan? If not what would be a good replacement to put on top of my 947U to keep this OC/d proc. cool.
My other Noisy Components:
2x 80 MM fans on my ENermax 460W PSU
North-bridge Fan on my Abit IC7-max 3.
Fan above the power capacitators on my IC7-Max3
9700 pro fan
2x120 MM Antec-Clear case fans (not noisy)
Raptor HD
ANy ideas???
Right now when I turn on the system it really sounds like a jet was just turned on. I live in a qiuet neighborhood no-less so the noise is especially apparent. The main step at first is the CPU fan but I am open for other suggestions to tame this beast.
Thanks!
9700 pro fan
Raptor HD
ANy ideas???
Thanks!
