Need Help! Prime95 Fatal Error BUT result is same as expected???
ChampionAtTufshop
Heya, this is a new one for me
after a random amount of time, it jst fails (usualy within 20min...somtimes 2, sometimes 5, sometimes 9) prime95 fails
HOWEVER, the kicker is the resulting sum is the exact same as the expected sum.... 😕
for example, right now, it just failed and it says:
FATAL ERROR: Resulting sum was 3.155715440852562e+029, expected: 3.155715440852562e+029
What's up?
maybe one of you ppl have seen this before and can tell me what is goin on 🙂
unless the first 16 digits are the same, but afterwards they are not? (and cant be seen by the user)
it is likley the numbers further down the line they are not showing you....I usually get the rounding error ...never seen that one...
yeah i know me either
the weird thing, i've only oced it like 100something mhz (xp2100+ tbred b)
...i just flashed bios to 1002.A
maybe its some weird bios thing
ive also ran HotCPUTester and BurnInTest and no errors on that, but on prime95 there were
...ill have to wait it out for now, theres homework to be done (goodbye spring break 🙁 )
