Need Help Plz LOOK!
jaygayPayCash
Banned
Mar 6, 2001
222
i have a project i have to do ,i am just about finished i just need to know how do you add in Visual Basics.?
i can subtract times and everything just not + please help
jaygayPayCash
Banned
Mar 6, 2001
222
hhumm ,i did didnt work this is what will happen
say i have
Text5.Text = Text1.Text + Text4.text
this is what happens text 1 is 40000 and text 4 is 3600
is text 5 i get 400003600
dopcombo
1,394
erm i dunno about visual but basic computer programming tells me that you can't "add" text variables.
maybe u shd reassign them as integers or double instead?
Jarwa
1,160
Use the Val statement for Text1.text and Text4.text.
For Example: Exam1 = Val(Text1.text)
Exam2 = Val(Text4.text)
[Edit] Had to correct my syntax errors!
Jarwa
1,160
The Val statement allows text box objects to be used as numbers.
Did this help any? Or am I way off base here?
Jarwa
1,160
Sorry, no I don't have icq.
Are you hard coding the 40000 and the 3600?
Or, are you getting those numbers from the user?
The Val statement allows you to get a number from the user from the textbox.
I can e-mail you the code for a program that I wrote that uses the Val statement. Would that help?
What are you trying to do with the program besides add two numbers?
jaygayPayCash
Banned
Mar 6, 2001
222
ok this is what i have
Text5.Text = Val(Text1.Text) + Val(Text6.Text)
now when i click on the button , it brings up the first number then when i hit it again , it adds them together.. hhumm , why dont it do it , in one click
Jarwa
1,160
Maybe try someting like:
declare variables
XXXXX = Val(Text1.text)
XXXXX = Val(Text6.text)
calculate
Addition = XXXXX + XXXXX
output the addition to a label
Label5.Caption = Addition
Hell, maybe that will help. Let me know.
