Ok, this is kind of a strange problem and I can't seem to find a solution. Maybe one of you guys can help me out. I have three computers in a home LAN sharing cable with the use of a Linksys Cable/DSL router (DHCP enabled). All three computers have similar setups, P3's on P3V4X's using Win98. Computer 1 & 2 are having no problems. They access the internet fine and see each other fine over the LAN. My problem is with computer #3. This computer accesses the internet fine, however, it won't see the other computers and it won't download files from the internet. This is a new computer I just built so everything is freshly installed. It is setup exactly like the other two computers.
My computers/LAN are set up as suggested by Steve Gibson. I use TCP/IP for internet (unbound to file/print sharing & Client for MS Networks), NetBEUI (bound) for LAN, and IPX/SPX (unbound) for LAN games. All three computers are showing up in the router's DHCP table.
Can you guys think of anything that would cause this computer not to download files from the internet. It will access web sites with no problem but will not download. Weird. Also if you can think of anything I am missing as to why the other computers won't see it. Thanks for your help.
