Need help please to connect vga to tv
Apocalypto
94
I need to know which cable do I need to buy, to connect my samsung f6510 40 inch to my gtx 780 please. Also am i able to see the pictures on both screens (my samsung 23 inch which is connected trough dvi cable and the other samsung 40 inches through hdmi cable? or do I need a convertor?
Thanks for everyone.
KingFatty
3,034
You can choose various options, but I would guess the easiest and cheapest choice would be to use an HDMI cable.
So you continue using your existing DVI cable for the small display, and then you also plug in the HDMI cable to the video card, and the big display.
But ultimately, your choice would depend on how many different ports your video card has, and how many different ports your TV has.
Apocalypto
94
thank you so much for your help.
but what do I need exactly to buy? A mini hdmi to hdmi cable? And Can I use the dvi cable and the hdmi cable at the same time?
Flapdrol1337
1,677
93
if both the tv and the gpu have a hdmi port you'll want a hdmi-hdmi cable.
if only the tv has a hdmi port you'll want a dvi-hdmi cable.
Gunbuster
23
Pretty sure all GTX 780's have a standard size HDMI. So you need HDMI to HDMI
Yes you can mirror the screens or do extended desktop in windows/nvidia driver.
