Need Help Please P5NSLI
brock01
105
heres the specs of this build:
-FujiPLUS FP-988D Silver-Black 19" 12ms DVI LCD Monitor - Retail
-LITE-ON 18X DVD±R DVD Burner With 12X DVD-RAM Write Black IDE Model LH-18A1P-185 - OEM
-Antec SmartPower 2.0 SP-500 ATX12V 500W Power Supply - Retail
-Thermaltake Swing VB6000BNS Black 0.8 mm SECC ATX Mid Tower Computer Case - Retail
-ASUS P5NSLI LGA 775 NVIDIA nForce 570 SLI Intel Edition ATX Intel Motherboard - Retail-
-CHAINTECH VGA256C-SE76GS GeForce 7600GS 256MB GDDR2 PCI Express x16 Video Card - G.SKILL 2GB (2 x 1GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-2GBNQ - Retail
- Intel Core 2 Duo E6400 Conroe 2.13GHz LGA 775 Processor Model BX80557E6400 - Retail
-Seagate Barracuda 7200.10 (Perpendicular Recording) ST3250620AS 250GB 7200 RPM SATA 3.0Gb/s Hard Drive - OEM
When trying to install windows xp, i get bsod's like 0x000007E, and 0x0000000A. Sometimes i can get as far as it formatting the hd, then it copies the files over, and when it copies the files over it will say like this "ieframe.dll" didnt get copied over correctly.
Im not sure whats wrong? do i need use F6, even though im not using raid at all?
any ideas are greatly appreciated.
Thanks
