Need help playing a game without CD plz
VAP0R
366
I have Star Trek Armada and my little brother broke the CD :(
I download a no cd patch to play it without the CD since its broken and instructions are
Apply the Official Star Trek: Armada v1.1 Patch.
Extract the KARCAW99_ST_ARMADA_1_11.EXE Patch from the Patch archive to the game directory.
Execute the Patch to remove the CD-Check from: ARMADA.EXE [2,396.205 bytes]
Play the Game!
I dont know what they mean by etracting it and the other steps. Help will be greatly appriciated. Thanks
Wizkid
2,728
Copy KARCAW99_ST_ARMADA_1_11.EXE to the directory where the game is installed and then double-click on it :)
VAP0R
366
I'm clueless, i copied the file and pasted it on the folder where st armade is installed and it still wont work.
plz be mores specific, thx
prodigy
After you copy the file you still have to run it first, before you can run the game.
