1. What YOUR PC will be used for. That means what types of tasks you'll be performing.
Gaming: Battlefield 3, Crysis 3, sport games..etc. Mostly offline missions though
2. What YOUR budget is. A price range is acceptable as long as it's not more than a 20% spread
$800, $1100; excluding parts under Answer # 5
3. What country YOU will be buying YOUR parts from.
USA
4. IF YOU have a brand preference.
No
5. If YOU intend on using any of YOUR current parts, and if so, what those parts are.
I have a crucial M4 240GB, Logitech KB+mouse, one of the korean IPS 27" 2560X1440 monitors (can't decide which one to get), A couple of 1TB 5400RPM HDDs for storage.
7. IF YOU plan on overclocking or run the system at default speeds.
Yes!
8. What resolution will you be using?
2560X1440 27" monitor.
9. WHEN do you plan to build it?
This week
X. Do you need to purchase any software to go with the system, such as Windows or Blu Ray playback software?
Nope.
I have a 3570k in my cart @ newegg, plus I guess I'll need a 680 card or a 7970( has more memory & 384bit?). I'd like to get a modular PSU unit, that will support SLI so I can add another card in near future to drive this screen at this resolution I guess. I haven't done SLI before, (my system that's going to be used as an HTPC has an e6750, ati 5850, 4GB memory, x25 M 80GB).
I still haven't decided on the case, motherboard ( I think I'll need something with 2 X16 pcie-x 3 minimum, right?
USA
No
Yes!
This week
Nope.
