need help picking out a scsi HD...URGENT
BigFatCow
3,373
just fell into a little more money so my budget opened up some..
now what i want to know is how much of a performance difference is there between the Seagate Cheetah X15 36LP and the seagate 15.3k drives...
i would like to order a hd tonight...
Old Post
well im wondering what you guys think about this controller card and the 1st or 2nd hd here
ive been reading up a little bit and it seems like the LSI controller cards are really good cards, i read about the HD at storage review here. and it seems like its a pretty good drive. But i still want to know what you guys think about this stuff expecially if any of you have used either of these parts in your own systems...
BigFatCow
3,373
Originally posted by: mcveigh
link doesn't work for me :(
check prices at hypermicro.com as well
hmm..well heres the hd at hypermicro its either the 1st or 3rd one..and heres the controller card at newegg, its the 3rd one down, or the $68 card...
Goosemaster
48,775
LSI is great...
as for the HD's seagates are very very loud.
I would recommend a maxtor 10kIII drive as they are realitively inexpensive.
If you are out for performance may I suggest you go to the HOT DEALS FORUM
HYPERMICRO has a deal where you can choose a variety of IBM SCSI drives and get an LSI controller for free
BigFatCow
3,373
Originally posted by: Goosemaster
LSI is great...
LSI has a deal where you can choose a variety of IBM SCSI drives and get an LSI controller for free
well i was actually looking at some of the ibm 15k rpm drives...
bozo1
6,364
The new Seagate 15.3 drives are not any louder than the IBM.
Don't get a drive with an 80-pin SCA connector. You'll have to get an adapter to go with it and they often cause problems. If you must go with an 80-pin drive, I would get one from Hypermicro as they include a converter that works properly, getting one from another vendor is a crap shoot.
Make sure your controller comes with a terminated LVD cable. If not, you need to buy one separately.
mechBgon
Oct 31, 1999
30,699
The 15000rpm Seagates use fluid-dynamic bearings. I have the X15-36LP and it's pretty civilized, although the seeks are more pronounced than IDE drives (go figure).
I second the motion to go with Hypermicro. For one thing, they pack stuff as if they care about it.
BigFatCow
3,373
well, im on a tight budget and compubuzz has a good deal on the IBM drive i was looking at and the controller card is also the cheapest on Pricewatch...
basically im just wondering if the ibm drive i am looking at is good for the money? and im pretty sure i will stay away from the 80 pin converter.
BigFatCow
3,373
the special includes 15k IBM drives
THe seagate 15.3k is the absolute fastest in case you wondered
i just fell into a little more money so my budget opened up some..
bozo1
6,364
Go here, click on 'Database' and you'll find a number of benchmarks - just choose the benchmark you want and it will show you the test results.
BuckNaked
Without hesitation I would go with the 15k.3 over the 36LP, better performance and runs cooler and quieter... I am thinking of replacing my Atlas 10K3 with the Seagate 15K.3...
Dave
