- Dec 15, 2006
- 666
- 0
- 76
Looking for a case with the following specs;
1.) Essential: Black inside and out.
2.) Essential: Cut out on mobo tray for easy rear access to bolt down coolers.
3.) Window or mesh on side would be nice, but not absolutely required.
4.) Essential: Able to fit dual 11" graphics cards. (5870's for now.)
5.) Not required but would like dual 2.5" hard drive mounting for 2 x SSD's
6.) Essential: Mid tower, ATX
7.) Would prefer PSU top mounting but not firm on this.
8.) Essential: Power/Reset/Audio/USB connectors on top, towards the front.
9.) Essential: Very solid build quality and good ease of use, I mess with my hardware often.
10.) Essential: Good system to route cables/wires for clean look inside.
11.) Fairly Important: ~$200 or less budget.
Do not need or care about;
1.) Fans, using my own cooling set up.
2.) Do not need a PSU
3.) Do not need any lighting. (Any lighted fans or LED's/cathode tubes will be removed.)
4.) Don't care about brand, just want a solidly built unit. No junk.
5.) Don't need any special abilities for water cooling, this will be an air cooled computer only.
I'm sure this is being pretty picky and I'm having a hard time finding something but if you have any suggestions please share them with me.
Thanks.
Thanks.
