Hey guys,
My HDD is dying and since I'm going to have to reinstall the OS and all my apps it seems like the right time for an upgrade--
I first need to decide what mobo and CPU to purchase, but I haven't kept up with the latest models and I would greatly appreciate some advice. Though, there are a couple requirements:
- I will be purchasing an AMD CPU (of course), probably an Athlon 64. I don't care about overclocking...
- The motherboard needs to have an AGP slot to work with my GeForce 6800, but it would be great if it had a PCI-E slot too for my next video card. Oh, and I don't care about SLI.
- I would like a good nForce chipset mobo that supports SATA as well as at least one PATA drive.
- I do not need the very fastest processor available; and it would be nice to have a mobo that supports a wide range of processors so that I can drop in a faster CPU in a year or two without upgrading the mobo and RAM.
- I can spend around $300 on the Mobo, CPU and RAM. I plan on buying 2GB of RAM if the budget will allow...
- I will also need to purchase a new heatsink, RAM, HDD and possibly a powersupply... but I'll worry about those after I get the mobo and CPU decided.
Other questions:
- Are there any nForce4 mobos that have AGP and PCI-E slots?
Thanks for any advice... I usually like to take a long time and do lots of research... but I am stuck without a useable computer at this point. 🙁 (well, except my work laptop)
TIA! Epsil0n
Other questions:
TIA! Epsil0n
