Indus
I upgraded my rig to a 7600 gs and have random reboots presumably due to not enough power.
I'm on a budget of roughly $70-100 (more saved the better assuming good quality powersupply).
I have an MSI GF 7600gs which says it needs 18-19 amps on a 5v rail (350 watts minimum). My antec 350 watt true isn't doing the job although it says 29 amps for 3 molex cables.
Also I need a 20 + 4 connector as I have k8n neo platinum motherboard. Can you help me pick a p/s or suggest one please.
1. http://www.newegg.com/Product/Product.asp?Item=N82E16817153028 (not sure it has enough amps).
2. http://www.newegg.com/Product/Product.asp?Item=N82E16817163104 (again not sure enough amps).
3. http://www.newegg.com/Product/Product.asp?Item=N82E16817182016 (like this one, sure it'll hold upto it?)
4. http://www.newegg.com/Product/Product.asp?Item=N82E16817148010 (same as 3)
Or do you have any other suggestions ?
My rig:
Amd 64 2800+ Newcastle
MSI MS-7030 (k8n neo platinum)
2 x 512 mb pc-3200 DDR sdram
2 x 120 gb hard drive
MSI 7600GS Video card (agp)
soundblaster 5.1
Lite On Dvd-rw Burner
D-LINK PCI Network Card
2 x 19" Samsung 915n LCD's
My rig:
soundblaster 5.1
