preacherofdoom
I was on Thermaltake's website and I found this case called the Kandalf which is designed for fanless setup. They have a picture with the case, a Thermaltake purepower 350 fanless psu, silent cpu cooler, and vga cooler. It's said to be certified by Thermaltake to work safely. I plan on buying all this and in case it gets too hot I'll leave the fans in since they are all rated less than 20 db and are placed in the front, top, and back of the case for good airflow. Only question is if I were to attempt the true fanless setup, which motherboard should I get? I was looking at the ASUS a8n-sli Premium cuz it has a heatpipe for the chipset. I"m not sure if this is good or will only make everything hotter. Any ideas on what I should do?
