Trying to decide between a Ninja, XP-90, and SI-120 to go on a MSI Neo4 Platinum...I plan to overclock, so I also need fan choices for all of these (Probably a Panaflo Low or Medium, but other suggestions are welcome).
I'd get the Ninja, but the weight and torque definitley concern me since the system will be standing vertically 24/7...if anyone can comfort me on these points, then that would be great 😛
According to Thermalright's list, the XP-90 might require me to bend some capacitors out of the way, but that's something I'd rather avoid (has anyone instaledl an XP-90 on this board?)
What about the Freezer 64 Pro? How does it compare to these others?
The problem with the SI-120 is cost - it comes in at a good bit more than the other ones listed here...once I get in this price range, what about the Big Typhoon or other options?
