- Jul 10, 2005
- 1,053
- 0
- 0
Hey guys,
I am about to buy an antec p180 but I just noticed that it only comes with two fans.... i am assuming there is no fan on the top blowhole (please tell me if i am wrong). Noise is a slight concern but i still want it to push out a decent amount of air. Money is of no concern. Please suggest a few if you can ... or even better one best one for me
Also, would you recommend replacing the two fans that it comes with?
I am planning on ocing an x2 3800+ as high as i can and i will be running a 7800gtx at first and might add another one in a year or two. So there will be a decent amount of heat.
Thanks
Thanks
