Socket 478, Pentium 4, CPU-P4-2.2 1 261.99 *Discrepancy & Shipping damage must
Intel 2.2GHz 512K 400MHz be reported within 7 days = OK
478-Pin Microprocessor,
(Northwood), Retail box
Asus P4B533-V Socket 478 MB-P4B533V 1 .00
motherboard, i845G, DDR,
USB 2.0, Audio, SPDIF,
Video, LAN
Chaintech NVIDIA GeForce4 VD-G4-Ti4600 1 .00
Ti4600, 128MB DDR AGP
Video Card with TV Out,
Retail Box
Sound Blaster Audigy SOU-Audigy-Gamer 1 .00 *Add Audio Cable = Yes,
Gamer, Creative Labs Single(+2.00)
Sound Cards / Adapters,
24bit, Part Number:
70SB009003002
DDR 1024MB 266MHz (PC DIM-1024-DDR 1 .00 *Discrepancy & Shipping damage must
2100) 184Pin Memory, ECC, be reported within 7 days = OK
Registered, OEM *Physical damage by user will void
your warranty = OK
*Test Before Shipping? = Yes(+4.00)
Black Antec Windows 98 KBD-Antec-b 1 .00 Add = PS2 M-F Extension
Keyboard, All the Power Cable(+4.00)
of Windows98, KF-898B,
Retail box
Logitech USB iFeel MOU-iFeel 1 .00
Optical Mouse, 3-button,
Retail box
IBM Deskstar 123.5GB HD-IBM-120 1 .99 *Add IDE Cable = Ribbon, 1,
7200RPM Ultra DMA EIDE ATA66/100(+1.99)
Hard Disk Drives, ATA100, *Add Mounting screws = Yes(+3.00)
OEM *Substitution OK? = No
Black Mitsumi 1.44MB 3.5" FD-D359M3D-MIT 1 .00 *Add Floppy Cable = Yes(+2.00)
Floppy Drive, internal, *Add Mounting Screws = Yes(+1.00)
D359M3D,OEM
Black TEAC 40X12X48X CDR-W540E-B 1 .99 *Add Add IDE Cable = Ribbon, 1,
Internal IDE CD-R & CD-RW ATA66/100(+1.99)
Drive, Model: CD-W540E,
OEM
Charcoal Black Pioneer DVD-P-115LG 1 .99 *Add Audio Cable = Yes(+2.00)
16x Tray DVD-Rom Drive, *Add IDE Cable = Ribbon, 1,
DVD-115LG/ DVD-116LJ, OEM ATA66/100(+1.99)
*Add Mounting Screws = Yes(+3.00)
Charcoal Black DELL MTR-32DVX 1 .00
1403FP 15''(15'' VIS)
1024 x 768 LCD Flat Panel
Monitor
Cyclone Blower, Antec FAN-A-Cyclone 1 .99 *Add 12-to-7V Power Adapter =
System Cooling Fan for Yes(+3.99)
Expansion Slot
Directron Koolance CS-601AE-KOOL-W 1 .95 *Add 12inch Cold Cathode Light Kit
PC2-601-W Large Tower = Yes, Blue 105B(+34.95)
Super Liquid Cooled Case, *Add 8cm Rear Fan = Two Quiet
w/Side Window, *P4 Ready* Panaflo w/4-pin(+34.00)
*Add Power Supply = Turbo-Cool
300W(+.00)
*Add 4 Thumb Screws = Yes(+4.00)
*Add Hard Drive Cooler Kit =
Yes(+.00)
*Add Motherboard Cooler Kit =
Yes(+.00)
*Add Power Cord = Yes(+1.00)
*Choose CPU Water Block =
CPU-200(+.00)
monitor says theres no video signal
what can i do?
Video, LAN
Retail Box
24bit, Part Number:
70SB009003002
your warranty = OK
Retail box
Retail box
D359M3D,OEM
OEM
Monitor
Expansion Slot
300W(+.00)
Yes(+.00)
Yes(+.00)
CPU-200(+.00)
what can i do?
