Need help - P180/A8n-E standoffs
teamcanada
I'm installing an Asus A8N-e in an Antec P180. However, there are only 3 brass standoffs included but 9 holes on the mobo. This is my first time building a PC from scratch, so be nice.
Thanks
Welcome to AT.
There should be a bunch of standoffs already installed into the MB tray. Those 3 are just extras to insert based on what holes the board you're using needs. The ones already installed are standard for most, if not all MBs. Good luck.
