I have a Abit BX6 rev2 mobo, IWILL Slocket II, P3-700E w/ CoolerMaster DP5-6H51. I want to overclock this bad boy. So I went into BIOS, set to 133mhz FSB, 2/3 AGP divider, and the PCI was at 1/4. Defualt voltage btw (1.65V). It posts, I get into Windows! Yeah! I run SiSoft Sandra and seems good. Temps are about 33C-36C. Then I play some Crimson Skies, runs well, no lock ups or stutters. Then I try playing Quake3. It loads game, then as soon as your start playing it locks up! And you have to reboot. I tried upping the voltage thinking that might help but to no avail.
So does this mean my video card can't run under the overclocked agp? Or is it the CPU itself? I have 2 x 128mbs of PC133 cas2 SDRAM from Crucial btw, so I don't think the ram should be a problem. Any other suggestions? New video card? Or new mobo?
Also, if I end up getting a new mobo, I was thinking the Asus CUSL2-C. Is it worth getting a new motherboard? Isn't there a bunch of new stuff from intel and amd around the corner? Should I just stick with 700?
Sorry for the long post and all the questions.
Thanks
Thanks
