i am trying to overclock my duron 600 to 800 MHZ but it will only register as 600 with the dipswitches set for 800. here are the settings i used according to the latest manual from asus site-
i moved the jen jumper to pins 1-2
i set the FSB bus switches to all in on position for 100 MHZ FSB
i set the multiplier switches to all on except number 2 & 4
i looked at my duron and the L1 bridge is solid line, i also left the voltage switches alone on board and didin't change it in bios, would this prevent it from posting at 800? someone else from another forum told me the asus manual is wrong to read the switch settings in opposite way from what manual says, i tried that and got some kind of siren when i turned the power back on. had to turn power off and switch settings. i currently am running in jumper free mode at 107 MHZ FSB with optimal settings rock stable. would like to try 800 MHZ or higher but am at loss as to what i am doing wrong. i have 300 watt power supply and FOP-38 with 7200 RPM fan so i don't think that is factor here. also am running 1004D bios. thanx for any help anybody can provide.
 Facebook
Facebook Twitter
Twitter
