Need Help Overclocking New Rig Having GFX Problems
djinnuk
Hi Guys Im new here but just looking for some advice, I just built a new rig and its a power full bit of kit (see signature), jumped straight into overclocking managed to get the ASUS P5W DH / E6600 Combo upto 3.7Ghz using only 1.55Volts and its totally rock solid stable, the board wont let me have anymore than 415FSB max..
Anyway thats not the problem my new EVGA Superclocked 7950GX2 is, stock settings on the superclocked are 550/1400, however if I run 3dMark06, as soon as the 2 HDR/SM3.0 tests come up at the end, the screens starts to flicker during the test then after a short while it locks up with garbled graphics, If I slow the core down to like 530mhz its seems to be stable, but I was looking to overclock the superclocked not slow it down!, I've read on other forums that people with stock 7950GX2's are able to hit 600-650mhz core on AIR, so I dont understand why my card is so poor.
I started to think that maybe my 580W PSU is not powerful enough to power this rig (at least the PCI-E anyway) when its maxxed out? My PSU has dual 12V rails, however on the side of the box for the EVGA superclocked it states that the PSU requirement is at LEAST 27Amps to GFX card, the booklet for my Hyper X PSU states that the PSU only supplys a max of 20amps to the PCI-E card and that this 20A is shared between the Mobo, Hdd's, and other peripherals in the system, basically the only thing thats get to use the 2nd 18A rail of my PSU is the mobo's 12v connector. So im assuming that the GFX problem could be power related? not enough juice maybe? although surely some of the required 27amps for the GFX is coming through the motherboards pci-express connector right? I read somewhere about 75w of power can be drawn from the mobo without even using the seperate pci-e power connector. Im confused, if I have a faulty GFX board I could do with knowing. Any help much appreciated.
You're right. You aren't going to be able to run an E6600 at 3.7 Ghz, along with two video cards (even if they only use one PCI-E slot), with that psu. You're going to need something with quite a bit more power than what you have now. A better brand name would help considerably, also.
edit: Oh, and you know that your Peltier is using power from your psu, also, don't you? You're gonna need a very powerful power supply for that rig.
This is what im thinking, The Peltier uses another 50W of power! it does keep the CPU cool tho 🙂. I think what I will go and try now is downclocking my core 2 duo to stock settings and reducing the Vcore to stock, then try testing my GFX again, thing is I started overclocking the CPU first then the GFX card so obviously I would not know if the extra CPU current being drawn is causing my problems and dont forget that when I increase the CPU vcore and clock my peltier is working flat out 24/7 (50w) extra. Have you got an idea as to how much power I need? I would assume a triple railed PSU would be best so I can feed the mobo, peltier/hdd's/dvd/rw and GFX all off seperate rails.
