- Apr 30, 2001
- 15
- 0
- 0
what procedures should i start with to overclock my 866?
also what is a safe speed that can be reach? (no need to gamble here)
here are my specs:
P3 866, 133 fsb 256k
Asus CUSL2-C w/ Intel 815EP chipset mobo
Award Bios (jumper-free = allows me to set everything in Bios)
PCI 32mb ddr Annihilator2 Geforce2 MX
384 sdram
my settings are
running: 866 mhz
multiplier: 6.5x (seems to be locked)
fsb:sdram
ci ratio: 133:133:33
lower voltage available: 1.70v
i.e setting speed to 906 mhz = 135:135:35 ratio
so on so forth. how high can you go on w/o major risk?
does higher heat from fsb, sdram & pci require me to get extra chassis fan?
what else should i modify or other approach to ensure good result?
thanks a ton
here are my specs:
384 sdram
my settings are
running: 866 mhz
fsb:sdram
thanks a ton
