Need help overclocking my 7900gt
zylander
I just volt modded my evga 7900gt CO SC. GPU at 1.49v, mem at 2.32v. Right now the card is running at 500/1500, this card is suppose to run at 550/1580. When I bump the ram up to 1580, my computer freezes and the display starts going in and out and I end up havin to reboot. The card runs fine normally and the voltages are stable but I just cant seem to overclock it just a little bit, let alone get it to run at its stock speeds. Any ideas? Im using rivatuner to OC btw.
RMA to EVGA, your card is defective. They have released a new fixed version of the 7900GT's and GTX's that fixes the memory problems.
I went through 4 cards before they released the fixed ones, but HL2: Ep 1 made me happy. 😀
First off, way too much voltage IMHO on the ram. They should get high enough on just 2.2v alone.
Second, yes, your card is probably deffective. But just to be sure, reverse the memory vmod and leave the core vmod and see if that helps (you should be able to run @ 800mhz on memory at stock volts. (since thats what fixed my 7900GT)
Would you really RMA it after you vmodded it??? 😛
I used the conductive pen voltmod. Also, following that write up, I raised the mem to 2.3 which is what it said, but Ill undo that and try it out at stock.
I was hopping I wasnt going to hear that its porbably deffective. This is the THIRD 7900gt Ive got, the first two were already defective, Ive already had to RMA it twice...Im getting sick of this ******. EVGA is not doing well in my book.
I'm not sure if the voltmod would invalidate the eVGA warranty, probably does, it's good but i doubt it's that good...
You're an idiot for trying to overclock when it didn't run at stock.
Was it a good idea? No. Were you right to start flaming? No. See you in three days.
AnandTech Moderator
Pen-modding invalidates the warranty on any graphics card, period.
This is simply another case of 7900 Syndrome, as some have come to call it.
Stock clocks on a 7900GT are 450/1320. You bought a factory-overclocked card rated at 550/1580. So yes, the card overclocks quite decently; it just won't handle being pushed any further than the factory overclock.
One problem with the factory-overclocked 7900GT's is that people assume its stock clocks are 550/1580 and expect significant overclocking above that, damaging their cards so that they can't even run at the factory overclock anymore.
Anyway, try reversing the vmod as wizboy11 suggested and see if that works.
I know, this third one I jsut got was suppose to be one of the fixed ones. 🙁
I might try haha.
I never tried to OC it, I tried to bump it up to its advertised speeds and when that didnt work I went back down.
Again, never tried to OC it past stock speeds.
Honestly Im probably just going to end up keeping it. I really dont want to deal with another RMA.
You should be able to RMA it. Just use alcohol to remove the core vmod. But like I said, reverse the memory vmod and run the memeory at 800mhz (1600 DDR rate). That might do the trick.
Update just for the record. I did what wizboy suggested and reversed the memory vmod and the card is fine now running at 700/810.
