I'm using the expert tool that comes with the card. Problem is that if I go even 1mhz over 480mhz (its rated speed), the screen goes white and I can't do anything. I have to reset the computer and then use "enable VGA" to get back into win2k. Anyone know why this happens? I should be able to go a little higher than 480 right? I'm using a planar LCD 17.4in if that makes any difference. In the AT review, they got their gainward above 500 so I don't think I should have a problem getting above 480. Especially when it runs perfectly stable at that speed.
Thanks
Thanks
